sub pops whan turning off amp
Discussion in 'AV Receivers & Amplifiers' started by Ross Lowe, Feb 24, 2013.
Tags:
  1. Ross Lowe
    Ross Lowe
    Feb 7, 2010
    Have a question regarding Tag Mclaren amp with an active b&w sub. I am running from the Tag via the pre out to the sub via line level. Its ok when turning on, however when i turn it off i must remember to turn the sub off first, then the amp. If i turn the amp off before the sub, there is a loud pop from the sub. Does anyone know how to fix this? Ross.
  2. orange55
    orange55
    Feb 27, 2006
    849
    London
    +423
    I get the same thing. I tracked it to the muting relays in the Tag an spoke to Kevin green about it. It can't be fixed.
    If you enable the muting relays in the setup as per manual to avoid digital noise it will do it everyone you channel on satellite tv. That's how I tracked it down to the muting relays and at power off they engage.
    I have reprogrammed my remote to switch off sub first before preamp.
    Sorry I could not be or more help.
