Sub placment....can you answer this ?
Discussion in 'Subwoofers' started by Bristol Pete, Nov 25, 2003.
  1. Bristol Pete
    Bristol Pete
    Oct 18, 2002
    5,665
    Bristol.
    +309
    Currently running my Rel quake with which I am happy, alongside the Mission M72 set. Great sound really, using a Sony STRDB870 rec.
    However, I have a query.
    At present, my sub is situated between the fronts, to the left of the center as I face my screen. If I were to move the sub to say....half way down the side wall of our cinema room, will the bass effectively fill the room a little more coherently, or will I not notice much difference, given LFE omni-sound type status?
    What I am saying is that occasionally, I feel that the front sound stage could be a little bass heavy.
    I suppose its a case of moving it and hearing it, but I wondered what you guys or gals might think - it could save me shifting it really !!!
    Thanks,
    Cap:)
  2. jjcarteruk
    jjcarteruk
    I have a Rel Quake running through a Denon 2803 to AE Evo 3b's. The Rel manual recommends placing it in a corner BEHIND the front speakers. Incidentally, it also recommends NOT using the spikes. (Wish I'd read that before screwing them in place!)
  3. Bristol Pete
    Bristol Pete
    Oct 18, 2002
    5,665
    Bristol.
    +309
    Despite not getting any replies when I posted this one, I did move the sub and found that it sounds/sounded best where it was.
    Always worth checking though.
    And I do not use the spikes either, definately better without.
    Regards,
    Cap:smashin:
  4. NicolasB
    NicolasB
    Oct 3, 2002
    6,450
    Emily's Shop
    +898
    So long as you your subwoofer is capable of producing enough output, the corner is the worst possible place to put it.
    There will often be a considerable amount of trial and error with subwoofer placement. But as a first pass, try this:
    - Put the sub in the corner.
    - Play pink noise through it.
    - Prowl around the room with an SPL meter.
    - Find the place where the sound being measured is at its quietest.
    - Put the sub there.
  5. jelly
    jelly
    Oct 1, 2003
    1,306
    41
    nottingham
    +9
    if the sub is behind the tv would the viberations mess with the dvd r amp and tv + sky box???
  6. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    I thought it works like this:
    - Put the sub on the couch (your listening place)
    - play bass heavy music
    - crawl around the room
    - put the sub where it sounds best
    :suicide:
