sub placement?
jcr71
having recently purchased some Adam t5v speakers for my pc, and being very impressed with the sound, im tempted to get their t10s sub.
my problem is whether a sub would work with my set up.
i have the speakers on stands behind my 3 seater sofa where i sit. the sofa is about 18 inches out from the wall and the stands make the speaker base about level with the top of the sofa.
my monitor/tv is on a coffee table in front of the sofa. the left side of the sofa is about 3ft from the wall and i have a small unit there.
the question is, where would i put a sub? ive never used one before, so no nothing about setting them up.
would it work behind/to the side of my sofa or does it need a clear path?
sm1ggsy
Hi , sub don’t need a clear path, stick it a corner try all corners in your room and just pick which sounds best
jcr71
thats good to know thanks.
do they need to be sat on the floor? could i put it on top of a wooden tv cabinet for example?
sm1ggsy
can Only say try it but normally there better in or near a corner you will get better performance that way ,, if it sounds boomy in a corner just move it away a little at a time
Derek S-H
