Sub placement?
Discussion in 'Subwoofers' started by sapkan, Dec 27, 2004.
  1. sapkan
    sapkan
    Jul 8, 2004
    492
    +3
    Can a sub be placed behind the listener with good results?
  2. Malky1903
    Malky1903
    Jul 2, 2003
    1,908
    48
    Aberdeen
    +64
    It's a case of suck it and see. If you have a large enough room, it should work well. Personally I find the sub up front between the front speakers works for me but each to there own and where the sub sounds best in your room.
  3. Roohster
    Roohster
    Jul 1, 2004
    2,345
    116
    Derbyshire
    +1,028
    I know subs are supposedly 'non-directional' but I tried mine at the back of th room and it was just annoying! It didnt "blend" at all.
    I think if you're going to place it at the rear it has to be a fair distance away from where you're sitting...but my recommendation is at the front.
  4. Jeff
    Jeff
    Jul 13, 2000
    5,489
    Basingstoke
    +256
    Behind is fine as long as it's a good position to start with, it's been setup correctly and is a low distortion sub. High distortion is often the thing that make a sub directional.
  5. sapkan
    sapkan
    Jul 8, 2004
    492
    +3
    behind the couch where the listener would sit is the only place I can really put it as to avoid being killed by the missus. I thought that the sub can be placed almost anywhere in the room but read a bose manual at a friend's place and it clearly stated that the sub should be at front of the room
  6. bob1
    bob1
    Nov 7, 2002
    4,313
    Sheffield
    +128
    I used to have a sub on my left hand side , it sounded good but i used to get the sensation of my left ear beinging bunged up so i moved it.
    Sub placement can be critical so it my not sound its best where you are thinking of putting it anyway.Give it a go,what have you got to loose.
  7. Jeff
    Jeff
    Jul 13, 2000
    5,489
    Basingstoke
    +256
    Bose is a bit different, they use a very high crossover frequency because of the cubes poor bass reproduction. At these higher frequencies the sub becomes very much more directional.
