Sub placement - behind TV?
Discussion in 'Subwoofers' started by balders, Jan 2, 2004.
  1. balders
    balders
    Jul 31, 2001
    451
    28
    +25
    Several people have mentioned before that a good place to put a sub is behind the TV. I'm considering doing this, but am concerned that the TV stand, which will also house the amp and DVD player, will pick up a lot of vibration from the sub.
    Most setups I've seen in demo rooms seem to have the sub next to the component rack, so I'm probably worrying about nothing ...
    Two questions though -
    1 - is this likely to damage the TV, amp or DVD player? (I'd think not).
    2 - is it likely to cause problems with the audio/ video quality (eg DVD player skipping due to being bounced around) ?
    Thanks,
    Balders
  2. Andywilliams
    Andywilliams
    Sep 27, 2002
    2,080
    notts.
    +63
    Hi Balders
    What sub have you got?.
    Gonzo.
  3. balders
    balders
    Jul 31, 2001
    451
    28
    +25
    It'll be the kef 2010 (I think) from the 2005.2 pack.
    Balders.
  4. Mark Ward
    Mark Ward
    Sep 12, 2001
    1,815
    41
    Kent
    +18
    Very unlikely to cause any damage.
    I wouldn't think it would cause too much trouble, so long as the sub isn't in contact with the cabinet.
    I had a Rel STrata II directly next to my rack and it caused no problem at all.
    My next door neighbor has his Yamaha YST-SW120 (or something like that) behind his TV which is in the corner of the room. It works very well for him.
    Simple answer is to try it and see whether you can tell any difference.
    Mark.
  5. balders
    balders
    Jul 31, 2001
    451
    28
    +25
    Cheers, Mark. I'll give it a go.
    Balders.
