youngsyp
Not exactly a build thread but, I thought this was the most appropriate place for this. I've just bought a tatty REL Q100E from a well known auction site with a view to completely refurbing it. I've bought a replacement driver for it and plan to renew and/ or upgrade appropriate components on the amp board. I'll also seal/ re-seal the panel joints on the inside, just for good measure. The final touch will be to rub down the exterior and re-paint it. So what would you recommend, paint wise, to do this? I kind of like the original finish or the 'default' satin black on the current BKE range would also be acceptable.
Any suggestions welcome.
Cheers,
Paul
Cheers,
Paul
