Sub Out on SACD 2910
Discussion in 'Blu-ray & DVD Players & Recorders' started by deanym, May 25, 2005.
  1. deanym
    deanym
    May 29, 2004
    1,782
    +141
    Does anyone know how to get a bass channel, from surround SACD?
    Everything seems set up correctly - 6 channel out from player to 6 channel in on AV amp. All the other channels work fine.
    Is there a settings list that I need to set correctly for this to work?
    Thanks.
  2. Andy_Lee
    Andy_Lee
    Mar 12, 2005
    98
    Telford Shropshire
    Hi Dean
    How many discs have you tried? Not all SACD contain all 6 channels certain older discs are just direct transfers of Quadrophonic masters. My 3910 outputs Sub channels when present on the source material without intervention from me.
    Andy
  3. deanym
    deanym
    May 29, 2004
    1,782
    +141
    only the dire straits brothers in arms that arrived today!!!
    poor me!
  4. Eddy Boy
    Eddy Boy
    Dec 9, 2004
    937
    28
    London
    +27
    You will find that on some discs, in the main classical recordings andsome others that you may not have a LFE or Centre channel. Check in the 2910s setup to make sure the sub is on and the fronts are set to Small plus any others, just incase it gets mixed in with the full range capable channels.
  5. deanym
    deanym
    May 29, 2004
    1,782
    +141
    Eddy,
    Managed to get it sorted, needed to reset all the levels both on amp and player. took a while but got it going!!
  6. Eddy Boy
    Eddy Boy
    Dec 9, 2004
    937
    28
    London
    +27
    Excellent! :thumbsup: Enjoy your setup.
  7. deanym
    deanym
    May 29, 2004
    1,782
    +141
    Cheers, thanks for the tips. :smashin:
