sub or not worth it?
Discussion in 'Subwoofers' started by WScarlet, Jul 16, 2004.
  1. WScarlet
    WScarlet
    Jul 16, 2004
    56
    Birmingham
    Wonder if you can make a decision for me I’m wondering whether to invest in a sub current setup is
    Mission 734 for front left and right speakers
    Gale Centre speaker (can’t see model number cost about £40/50 at the time)
    JPW mini monitors for 2 rear speakers
    Yamaha HTR-5630rds amp
    Any think else you need to know?
    I would only have about £100ish max including buying the sub cable to spend tho, thoughts?
  2. DonMaico
    DonMaico
    I just bought me a sub and I would definitely say it was worth it. Make sure its a good one tho' :thumbsup:
  3. WScarlet
    WScarlet
    Jul 16, 2004
    56
    Birmingham
    which sub did you buy and how much? from reading other threads in this forum unless you pay 200 + pound for a decent sub peeps don't seem to think its worth it?
  4. Dfour
    Dfour
    Jan 19, 2004
    4,091
    71
    Bracknell
    +86
    From what we have found out that there are precious few good subs under £200. If you can find a second hand Paradigm they are quite a bargain and not to shabby for movies, just a little slow on music. Once you have a good sub you wont look back:devil:
  5. WScarlet
    WScarlet
    Jul 16, 2004
    56
    Birmingham
    ok Thankyou for your help which Paradigm model subwoofer should i be looking at? i can see a few on ebay atm so will watch what they go for
  6. Dfour
    Dfour
    Jan 19, 2004
    4,091
    71
    Bracknell
    +86
  7. WScarlet
    WScarlet
    Jul 16, 2004
    56
    Birmingham
    ye thats the one i saw :D lets just hope it don't go to high, thanks again
  8. Dfour
    Dfour
    Jan 19, 2004
    4,091
    71
    Bracknell
    +86
    You can also ask Kazman if he still has his as he wants to get a SVS, so he might be in the mind to sell his. If nto I would advise you to save your money till you have enough to get a better sub £2-£300.
  9. WScarlet
    WScarlet
    Jul 16, 2004
    56
    Birmingham
    if i did save for a sub for over 200 pound which one would i get?
  10. Dfour
    Dfour
    Jan 19, 2004
    4,091
    71
    Bracknell
    +86
  11. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,545
    Near London.
    +208
    I'd definitely agree with DFour. It's worth considering any cheap Paradigm really, the PDR, PS and PW get progressively more expensive but are probably the best you'll find at the price, although you will have to put up with second hand (not usually a problem with subs, especially when bought off this forum).
    If you get bored, read this thread to see some of our research into this for helping people in your position :)
    http://www.avforums.com/forums/showthread.php?t=137930
  12. WScarlet
    WScarlet
    Jul 16, 2004
    56
    Birmingham
    thanks for the help guys i've just found out off someone in work they have a paradigm pdr10 sub and they said they will let it go for £100 should i take it? if yes what cable do you recommend me getting? only need it 3meter ish long to connect to my amp.
  13. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,545
    Near London.
    +208
    I think between £80-£90 would be a fairer price but it's still worth a whole ton considering they're getting rarer.
    I'd recommend making your own cable if you're at all capable with a soldering iron because it can be done for practically nothing (plenty of threads on DIY cables in the cables section.), otherwise one of Mark Grants from the Power Buys would do the trick.
  14. WScarlet
    WScarlet
    Jul 16, 2004
    56
    Birmingham
    think i'll take it then i don't have to worry about any courier cost or nowt cosidering his at work, i'm chuffed :) :)
    I ain't much good at diy :/
    Will look at the power buys section for mark grants cable thanks again! :) hopefully he'll bring it in tomorrow! :))
  15. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,545
    Near London.
    +208
    Excellent, let us know how you get on with it and whether it's a worthy addition :)
  16. Kazman
    Kazman
    Jan 14, 2004
    5,351
    Luton, Bedfordshire
    +142
    Small world.
    WScarlet and I go way back, nice to see you around here mate :)
    The Paradigm is nice little movie sub, you may be a little dissappointed with it for music though, it's a bit too slow and flabby for music imho, but a great bargain buy for movies.
    And trust me, if you hook it up to your PC soundcard, you will feel those rail slugs go through you :D
  17. WScarlet
    WScarlet
    Jul 16, 2004
    56
    Birmingham
    Long time back :) very small world
    will be mainly using it for movies
  18. WScarlet
    WScarlet
    Jul 16, 2004
    56
    Birmingham
    Ok got it setup, sounds great i'm happy with it (remember i can't compare to any other subs this is my first one) The extra sound i get in films now is cool more the merrier, very happy i finally got one :)
    ps just worry about the neighbours at times :/
  19. Dfour
    Dfour
    Jan 19, 2004
    4,091
    71
    Bracknell
    +86
    I cant remeber if the Paradigm has feet on it or not. If it hasnt its worth getting some spikes for it as it tightens up the bass quite well. If it has rubber feet its also worth replacing them especiall if the sub sits on a carpet. Good improvment for not much money:)
    http://www.richersounds.com/index.php?f=itemdetl.php&p=201695
  20. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,545
    Near London.
    +208
