Sub on or Sub off?
Discussion in 'Subwoofers' started by GaryG, Dec 28, 2000.
  1. GaryG
    GaryG
    My sub has been switched on for the past couple of years without problem.
    Regards
    Gary
  2. gwbailey
    gwbailey
    I've got two M&K active Subs and it says in the manual that you should leave them switched on all the time. Even if you're not using them.
    Is this true?
    How many of you leave them switched on?(when there not in use)
    I would be interested in your views.
  3. simonsez
    simonsez
    I have two subs which I leave on full time....for that matter I leave my Bass Shaker amps on all the time as well.
  4. Stuart Wright
    Stuart Wright
    AVForums Founder Staff Member
    Jan 24, 2000
    13,808
    2
    167
    Birmingham, UK
    +9,527
    As I understand it, you cause most wear and tear to most things when starting and stopping them. Leaving them running is usually best for them.
  5. gwbailey
    gwbailey
    Thanks guys, there was not much in the way of replys thats why I didn't get back to you sooner sorry!
    So it looks like I will be leaving my Subs on from now on.
    Once again thanks.
  6. Spaceman
    Spaceman
    Electronics don't like it to heat up and cool down. Also, amps are more stable when turned on for a few hours so you might just leave em on. REL is even forcing people to leave their subs on, because they haven't included a turn-on delay. This will cause a loud boom when turning it on. :)
