Sub on Carpet or Wood Floor?
Discussion in 'Subwoofers' started by Timh, Jan 20, 2003.
  1. Timh
    Timh
    Sep 14, 2000
    5,270
    3
    3
    Altair-4
    +339
    I have a Jamo sw-400 subwoofer (not a very good sub) which is vented and fires downwards onto a Laminated floor, sitting on rubber feet. I am going to try sitting the sub onto a piece of carpet, (spiked) to see if there is any differance in base and sound quality.
    Has anyone else tried this, if so what were your results.
  2. EvilMudge
    EvilMudge
    I wouldn't try it. I tried sitting my PS-1000 on a sheep skin rug, and it sucked out quite a lot of the bass. That's a bandpass design which only outputs through the rear. Unless you have real problems with overblown bass sitting it on a rug is probably not going to improve matters. Try sandwiching it between two concrete (or marble) slabs and see if this helps. Searching for slab and sub should bring up the relevant thread.
  3. Timh
    Timh
    Sep 14, 2000
    5,270
    3
    3
    Altair-4
    +339
    Thanks Mark, i will have a search.
  4. Brad_Porter
    Brad_Porter
    Yeah - placed my V-125 on a slab and this did make a positive difference to the sound........
