sub newbie
tidytrev
Established Member
iv just bought myself a set of acoustic energy evo 3's and was looking to add a sub, iv never used a sub before as iv always used a cheap satelite setup.
what i wanted to know was on the back of the sub there are ports for speakers, why is this?
i thought the sub just plugged into the back of my amp like all my other speakers :confused:
kbfern
You can connect the sub by speaker wire from the a/v amp's speaker outputs to the subs speaker inputs.Then connect your speakers to the subs speaker outputs.
However if your receiver or amp has a sub out(usually phono) just connect the sub to the amp with a phono lead and connect your speakers to the amp in the normal way.
I doubt if you will see any real difference whichever method you use.
tidytrev
Established Member
oh so it goes inbetween the amp and the speaker?
my amp is brand new and it has a sub in so i think il take the easy route
tidytrev
Established Member
can anybody tell me if adding a sub will increase the performance of my speakers, will the bass be taken from the fronts and routed all to the sub or do the fronts still give out bass?
🎬 The Top 20 Most Anticipated Movies of 2024
Back
