Sub needed to go with Bose AM6 set up.
Discussion in 'Subwoofers' started by Godzooky, Aug 24, 2002.
  1. Godzooky
    Godzooky
    I have Bose AM6 speakers running through Denon 1801 receiver. I have read lots of threads about Bose, mostly bad, but I have had them for a year now and taking into account size, etc, I am very happy. I upgraded from Videologic all-in-one system and the difference was immediately noticeable.
    Anyway, the only thing I am unhappy with is the Accoustimass unit. Can I add a separate sub to my system? Will I be able to run it alongside the Accoustimass or separately? Any recommendations for a good sub or does anyone have one for sale? REL seem v good bit as I don't get to use the system as much as i'd like (due to neighbours, girlfriend and son!) I don't want to break the bank.
  2. Jase
    Jase
    Mar 16, 2001
    10,735
    United Kingdom
    +2,520
    You could connect a second sub either by using a Y splitter from the back of the amp or connecting the sub via high level (speaker connections) to the relevant terminals on the amp. You would probably then have to change speaker settings in the amps menu as well. Large/Small etc.
    What sort of budget were you thinking of spending?
  3. Godzooky
    Godzooky
    £100 - £200.
  4. Jase
    Jase
    Mar 16, 2001
    10,735
    United Kingdom
    +2,520
    You could pick up a 2nd hand Rel Q100 for that. Might be worth checking out the Paradigm range of subs at Richer Sounds as well, models like the PDR10.
    Keep an eye on the Hardware/Classifieds Forum as 2nd hand subs appear there from time to time.:)
