Sub location
Discussion in 'Subwoofers' started by DSM, Jun 14, 2002.
  1. DSM
    DSM
    Jun 14, 2002
    87
    West Wales
    Hi, this is my first post. I have nearly finished building my HC room (20' x 11'), I am using : Barco G 808s, 80" x 60" Daylite screen, 4 x B&W DM603, 1 x B&W CC6, 1 x Jamo centre 200 (for rear centre) & SonySTR DB 1070 amp, the sub is a REL Storm - I cant put this in a corner because the front & rear speakers are there so where should I place it, I need to put the phono & power sockets on the wall and want them as close to the sub as possible. I was thinking of putting the sub under the screen between the centre & left or right speaker. Any ideas would be appreciated.
    Dave
    ps anyone got a scaler for sale.
  2. Electric Mayhem
    Electric Mayhem
    Mar 16, 2001
    10,465
    United Kingdom
    +1,941
    Putting the sub between the centre & either the left or right speaker should be ok, you´ll need to experiment with the position to see which spot sounds best.
    How about putting a Wanted post in the Hardware/Classified forum for the scaler??
