Sub Lfe Cable
Discussion in 'Subwoofers' started by sarll, Dec 23, 2003.
  1. sarll
    sarll
    Mar 19, 2002
    1,393
    63
    +126
    I am looking at purchasing a sub over xmas but before I do I have some queries over the lfe cable. The sub would ideally placed in a corner in my lounge but this would mean that the cable has to negotiate a doorway to get to my av amp. Does the quality of this cable really matter? Or can I just get a small and unobtrusive cable to run round the door frame?????
    Basically if i have to get a 'thick' cable my plans are scuppered as girlie will not allow this!
    Cheers guys
  2. stevegreen
    stevegreen
    May 14, 2001
    8,745
    in my Hymer
    +921
    The quality of cable will make a difference, but better a sub with a thin cable than no sub at all. I'd get away with what you can for the meantime and upgrade later on! :D
    You could also consider different postitioning of the sub to allow you to have a better cable.
  3. mudan
    mudan
    Nov 26, 2001
    226
    Solihull
    +18
  4. sarll
    sarll
    Mar 19, 2002
    1,393
    63
    +126
    cheers for that mudan, i'll have a look at those qed cables!
  5. philmate
    philmate
    Nov 6, 2000
    217
    Southend-on-sea
    +4
    See Mark Grant's sub cable in the Power buy section.
    Philmate.
  6. chris
    chris
    Nov 20, 2000
    1,226
    romney marsh, kent, uk
    +28
    Make your own.
    Get some 75 ohm Coax cable and some decent plugs and then you will have a decent sub cable just as good as any you would buy.
    I have found no diff between a cable that cost me £5 to make or a cable that cost me (i really paid for this.....:suicide: ) £30.
    If you make your own you can have any length you like and because it only cost a few quid to make, you can paint it any colour you like, to blend with you interior decor.
    One point i must add thow...is you have to be able to solder, although only a Monkey would not be able to...................or would he.........(Sorry to any one that cannot solder.....:D ).
