Sub level setting
Discussion in 'Subwoofers' started by andyk, Apr 26, 2002.
  1. andyk
    andyk
    Dec 31, 2001
    767
    46
    North Yorkshire
    +166
    I have a KEF sub and two questions.
    I am using the line level input.
    1. Does the crossover frequency control have any effect or is it only relevant if using the high level inputs? (I don't think that it should, but just in case I currently have set it to the highest level to let my amp (Denon 2802) control what goes to the sub).
    2. Should I set the level using the sub volume control or the level in the amp config?
    Andy
  2. S H A D O
    S H A D O
    Mar 16, 2001
    10,301
    United Kingdom
    +1,575
    Its best to set the sub crossover to maximum as the amp controls the cutoff frequency.
    I have the Low Level volume on my sub set to around a third, others have it halfway or more, and then use the amps SW Channel Level to fine tune it (mines set at -3db now).
    For the High level connection the volume is set at about quarter volume.
