UMAR 3:16
- Joined
- Feb 9, 2005
- Messages
- 10,307
- Reaction score
- 3,035
- Points
- 2,295
Question, after running XT32, my main sub volume on the sub is barley turned. As in probably the 35 position of the dial. The calibration shows the sub level at -3.5 in the 8805. That I adjust to around +5.5 to bring up the bass. Is that correct or should I be turning up the main volume on the sub itself? The sub is a monster SVS PB12 Plus 2 so power is not an issue for it. I could probably turn the volume in the 8805 to max and it would handle it. Just to summarise my question is, which is the best way to turn up the volume? Through the processor or the sub itself? And if it’s through the processor which I’m doing now as I find it sounds smoother than the amp plate, is there a limit to turning it up?
