Sub - Howz yours set?
Discussion in 'Subwoofers' started by Stellavision, May 3, 2003.
  1. Stellavision
    Stellavision
    Apr 7, 2003
    2,287
    Southsea, UK
    +96
    I've got a slight dilema at the moment. I can't find a happy medium for my subwoofer level.
    The problem I have is that some movie sound tracks are quite lfe heavy while others sound quite lite.
    The sub level on my Pioneer is at the moment set to -5 db, about 4 db less than my fronts (-1) and my crossover is set to 80 hz. (All speakers are calibrated to 75db)
    Just curious to how some of you have your sub set up in relation to your fronts?
  2. Hawklord
    Hawklord
    Feb 15, 2003
    3,446
    2
    Aldershot, Hampshire
    +267
    Both my fronts are set to 0 and my sub is set on -8 for dts/dd and -4 for tv (prologic2). For cd stereo playback is at -6. My denon alows me to specify for each function so after a bit of playing about settled on the above.
  3. mick23
    mick23
    Mar 20, 2002
    801
    uk
    hi hawklord
    could you give some info on how to set up the differant sub levels with 3802, as i feel this may be part of my problem with vx10 dvd\music not sure how i accssess and set the levels for music vs dvd with 3802, get the gist of 3802 settings one day thank you
  4. Jase
    Jase
    Mar 16, 2001
    9,534
    UK
    +932
    Doublecheck that because the Denon's will lump Dolby/DTS/PL2 as one mode, if you change the SW channel level for one it will have a knock-on effect for the others. Stereo/Direct etc can be adjusted seperately.:)
  5. Jase
    Jase
    Mar 16, 2001
    9,534
    UK
    +932
    When you are in each mode, press the Ch Vol button on the front panel and then cycle thru the options until SW appears then adjust up or down using the select button. Hopefully this is right as my current Denon has a different way of doing this.:)
  6. Hawklord
    Hawklord
    Feb 15, 2003
    3,446
    2
    +267
    Yes that's how I adjusted my sw levels on each channel.
    Sorry I didn't reply earlier was out auditioning kit last night:D
