sub high level cables
Discussion in 'Hi-Fi Stereo Systems & Separates' started by cradleoffilth, Jun 10, 2003.
  1. cradleoffilth
    cradleoffilth
    what is the best cable to connect my sub via the high level in? should it be the same as my main speaker cable? thanks:smashin:
  2. tvr
    tvr
    Aug 21, 2002
    443
    Bucks
    +4
    Yes, any speaker cable will do the job.
  3. cradleoffilth
    cradleoffilth
    ok thanks, just wondering if there was any particular cable that would work well
  4. Crocodile JD
    Crocodile JD
    Dec 11, 2002
    1,090
    41
    Tamworth, Staffs
    +21
    cradleoffilth
    What does connecting to the high level actually do? Never quite understood it.:confused:
    Crocodile JD
  5. cradleoffilth
    cradleoffilth
    it uses speaker cable connected to the amp and then into the sub rather than using the pre out. its better because the sub receives the same siganl as your main speakers
    [​IMG]
  6. Crocodile JD
    Crocodile JD
    Dec 11, 2002
    1,090
    41
    Tamworth, Staffs
    +21
    Oh I see what you mean. However, I've got that but I've also got a High pass on the line level as well. That's the bit I don't get. It's the PSW2000 Sub that comes with the Kef eggs. Any Idea?
    Croc
  7. wookie
    wookie
    The sub receives exactly the same signal as low level.
    It is simply attenuated back down to low level pre amp voltage.
    Utter utter crap about "receiving the same signal".
    Only slight issue could be phase irregularities (spetl wrong).:D
  8. cradleoffilth
    cradleoffilth
    i read it on rel's site so don't blame me :D
  9. wookie
    wookie
    It is just that high level inputs have to be "stepped down" or attenuated back to low level.
    You may as well just run the sub from a pre amp or av sub out.
    The only use (as far as I am concerned) for high level inputs is if they have a high pass filter to allow use of sats/standmounts with a sub and acheive easy integration. (Sub uses what it can and speakers fed a clean filtered signal).
    yyyaarrrrgghhhhh
    We're caught in a tractor beam chewy...................
  10. wilber
    wilber
    Sep 29, 2002
    1,970
    +30
    High level is also useful if your amp doesn't have a low level out - like my Rotel
