heh, through some great help from the guys at HT shack I managed to get a few steps further in the proces of calibrating my sub.
I'm not sure I'm doing the right thing here and I don't know very well how to interpret the graph. First I connected the soundcard to my receiver with my left speaker integrated and set it to cd mode (as the though coax dvd mode it didn't work). I did the checking levels routine and got to 12db both on the input and output VU meter while my SPL meter pionted to 75db. But during the measurement routine the headroom indicated that there was some clipping during the proces of the sweep sound. So I'm not sure if I did the measurement at the right level, although the level seemed to be fine during the pink noise rumble.
I did about 4 sweeps and first set to played in one minute and later over 20 seconds as it didn't made any difference.
The result made me feel even more confused. If I interpret this graph correct then it seems that between 20hz and 30hz there is a dip. I find hard to believe as during a lot of bassy scenes beneath 30hz I sence a boom. especially during the WOTW scene just after Tom Cruise says "it's freezing" there is this long continues boom that goes louder and louder.
I also didn't expect the 40hz peak. I'm almost sure that the booming sound is located around 25Hz.
anyway, I tried to set some parametric filters for the 40Hz peak but I though I should try to set a filter for 20Hz of about 0.5 octave wide. The result was that the boom was much less, I still felt the bass beneath 20Hz but still missed a bit of punch above 20Hz.
Can someone help me and say if I did the measure properly and where I should best set the filters?
