Question Sub for my Dynaudio BM5A monitor speakers
firestormer
Looking for suggestions to improve the bottom end of my Dynaudio BM5A monitor speakers, they're active and driven straight from a DAC, so it'll be simpler if I can find a sub that does high pass passthrough, failing that suggestion for a suitable crossover which needs to be decent SQ, small ish and cheap. The BM5A have phono and XLR balanced inputs and their own simple high pass filter.
It'll be mainly for music in a 4x3.5m room. I also have a 5m x 8 m room I may move it to. So ideas for the smaller room and larger room please. Budget, £300-500. Secondhand is fine.
I'm after accurate, "fast" bass, none of this flabby stuff. Cheers.
The back panel.
The speakers
Ultrasonic
What model is your DAC? The answer will depend on your available outputs...
This is for a 2-channel setup rather than one where you want the sub to take a separate LFE signal, right?
firestormer
Objective DAC, USB->single-ended stereo out (RCA socket), so just the single output.
Ultrasonic
You need to use some sort of splitter plugged into each of the two RCA outputs, with the cheapest option being a pair of something like this:
An XXLS400 sounds like a good option for your 4 x 3.5 m room. If you do end up moving to a 5 x 8 m room you may need a rethink though as that is getting on for three times the volume and so a rather different proposition.
Ultrasonic
For info I'm unusual amongst most posters here in that my system is 2-channel music focused. I'll just mention that I've had very good results in using miniDSPs to integrate my subs and main speakers, including importantly applying filters to minimise the effects of room modes. This would be more expense and work but something for you to bear in mind as a long term option.
firestormer
If it ends up in the larger room, I'll probably get another XXLS400.
In the mean time it'll be a single one. I've looked at minDSP, very interesting pieces of kit. In the past I've mess around with Behringer gear with sound processing and digital crossovers.
Podcast: Reported HDMI 2.1 bugs, Audiolab Amp & LG LED Projector reviews + Best of the Month
