sub for basic system
Discussion in 'Subwoofers' started by GuitarGray, Jan 20, 2003.
  1. GuitarGray
    GuitarGray
    hi i have a basic home cinema setup a cheep dvd player that has 5 speaker outputs for 5.1 , a pasive sub (that seems to produce small amount of bass but no thump) and a active sub output.
    i would like recomendations on a active sub to give me thump at medium sound levels.. i.e half volume..
    greatfull for any help at all as im a audio virgin ....
    Graeme
  2. GuitarGray
    GuitarGray
    30 views and no advice i dont believe it..
    come on lads i cant be the only one who has a starter kit and wants too improve it
  3. richard plumb
    richard plumb
    Jan 27, 2002
    14,514
    Windsor
    +1,054
    how much is your budget?
    I have a paradigm PDR10 from richer sounds (cost about £150 I think). Good for the money IMO.
    Several people here will actually recommend no sub is better than a cheap one, but if you have a cheap system and just want a bit more kick, then I see no problem with a cheap sub.
  4. SteveG
    SteveG
    Jan 14, 2003
    1,041
    London, UK
    +92
    I've got a REL Quake (cost around £290) which suits me perfectly as positioning was a bit of a problem. If space is tight this is the answer as it's *very* small. Sounds excellent in a smallish room (mines about 14ft x 13 ft).
    SteveG
