Sub for audio
Discussion in 'Subwoofers' started by Buckland, Dec 22, 2003.
  1. Buckland
    Buckland
    Dec 15, 2003
    40
    Hi, i'm new to the site so please forgive my ignorance
    I'm just building a hifi/av system. Bought a pair of Dynaudio 72s for front l/r which sound fantastic for audio. Also bought a REL 150 sub for AV.
    Is it worth using the sub for 2 channel audio? The rel blurb says it is. But the dyns seem pretty good on their own.
  2. Matt F
    Matt F
    Jul 18, 2000
    900
    Chester, UK
    +4
    Unless you listen to music with really low bass (i.e. under 25Hz) on it then I'd stick with the 72's on their own as they go pretty low (down to 28Hz according to Dynaudio).
    I used to own the Q150's bigger brother (the Q200) and didn't find it to be that impressive with music.
    Matt.
