Sub for <£100 to go with Home Cinema AV centre
oliphillips
Looking to spend around £50 ideally, but looks like I may have to branch out a bit!!
YAMAHA YST-SW012 £69 + DEL
KENWOOD SW-40HT £71.99 + DEL
Yamaha YST-FSW050B £80 + DEL
Eltrax Liberty Sub £79.95 Collected from local Richer Sounds
Eltrax Monitor Sub £79.95 Collected from local Richer Sounds
Tannoy SFX Sub £99.95 Collected from local Richer Sounds
Which one do you reckon is better guys? Going to be connecting it up to an AV Reciever to use it in a surround sound setup, Will they do the trick?
Cheers, Oli
KhalJimbo
I had the tannoy before I got my Monolith and its not a bad little sub
Oipete
I fully appreciate not everyone either wants to or can afford to spend more on a sub and only you can know your budget.
What I would say though, if you can up your budget a bit or even save for a bit longer, the reward would be well worth it. Alot of people have asked this question before and I have read members advising they save for a bit longer.
At the end of the day though mate, if you end up being happy with your setup, that's all that matters.
Member 639844
Former Advertiser
Have a look at this, it seems to offer so much more than the competition on paper at least and is within your budget. There are one or 2 of us that believe this could be the only sub of choice at this price, and to beat it you need to look at the £200 BK Gemini.
