sub ext level
killer10971
sub ext level , what is this setting on my denon amp and the default is 15db and is a seperate setting from the speaker adjustments which also include a subwoofer adjustment setting
many thanks all
Nimby
Since you seem to be flogging a dead horse on the sub forum you might like to raise your question on the Integrated Amps and Receivers Forum. You might get a bite over there.
My wildest guess would be that you are being given a choice between extension or output. A sort of music v film setting. But then 15dB sounds completely illogical in this context.
Nimby
I hope you have better luck on the other forum.
I hate unanswered questions.
Let us know if you get a proper answer and we can memorise it for next time. ;)
Similar threads
