SuB-DEAL
Discussion in 'Subwoofers' started by Chaos Star, Jan 12, 2003.
  1. Chaos Star
    Chaos Star
    Jan 9, 2003
    1,951
    38
    Scotland
    +20
    Yamaha DSP AX-620 (AMP)
    Pioneer A-300x (stereoamp)
    Mission 702e (FRONT)
    Mission 700 (REAR)
    Mission 70Ci (CENTRE)
    TOSHIBA SD-210e (DVD)
    Marantz cd 52mk2 (CD)
    Okay peeps lookin for a decent subwoofer to compliment this system.
    £100 to spend what can i get for my money and where do i get it.
    Ps.Prefer woofer that has been reduced cause it old modelor sumpthin
  2. lynx
    lynx
    Jan 20, 2002
    4,651
    It always rains.
    +302
    [​IMG]
    Under £40. RS
  3. Chaos Star
    Chaos Star
    Jan 9, 2003
    1,951
    38
    Scotland
    +20
    Is it any good at £40would assume its a bit duf?
  4. lynx
    lynx
    Jan 20, 2002
    4,651
    It always rains.
    +302
    Anything that you buy at or around your suggested price ( unless you can get someone to sell you a cht 15 etc for £100 ) will be compromised.That way you would only be £39.99 down instead of £100 down :) . Can you raise your budget a bit ?
  5. Chaos Star
    Chaos Star
    Jan 9, 2003
    1,951
    38
    Scotland
    +20
    Okay if a £100 is a waste,then how much do i have to spend to get a decent sub. Where are the good deals at moment and what subs should i be looking out to purchase.
    £150 do the JOB?
  6. stranger
    stranger
    paradigm pdr10 from richer-vary from£120.00 to £169.00 depending on current offers, check their ads inWhat hi-fi mag as they're usually cheaper (quote whf if you visit richer)
  7. Chaos Star
    Chaos Star
    Jan 9, 2003
    1,951
    38
    Scotland
    +20
    Is the pardign sub any good and if so whats the price in what hifi this month so i can run out and get one, desperate for a sub.
    :D
  8. Ian J
    Ian J
    Aug 6, 2001
    25,628
    +4,905
    The Paradigm sub is good value for money. As for the current price in What Hifi, I'm sure that you have a newsagent near where you live or work :D
  9. Chaos Star
    Chaos Star
    Jan 9, 2003
    1,951
    38
    Scotland
    +20
    Well Ian i do have a news agents in my humble village though they do not stock what hifi, so someone save me a 20 min journey to nearest town a tell me the price of the sub in what hifi.
    Plllllllleeeeeeeeeeease, u will save me £3.00 as well.
    REMBER SCOTS ARE TIGHT WITH THE LOLLY.:p
  10. amordue
    amordue
    Nov 13, 2002
    101
    Edinburgh
    The Sony SA-WM40 is pretty good for the money. £145 or so new, however you may be best off just trying to find something second hand here on the forums, or perhaps on music.loot.com
    Alex
  11. Chaos Star
    Chaos Star
    Jan 9, 2003
    1,951
    38
    Scotland
    +20
    So does anyone have the price of a paradign sub from Richard Sounds, that is quoted in this m,onths what hifi.
    :confused:.
    Bet u got it phantom poster Ian J, search through that mag & tell me the price so i can send of my girlfriend to buy the sub.:p
