Sub connection
Discussion in 'Subwoofers' started by mjhbell, Jun 7, 2004.
  1. mjhbell
    mjhbell
    May 26, 2004
    19
    Just a quick question:
    Hooking up my Mordaunt Short MS309 Sub to my Pioneer VSX-C501 receiver.
    The pioneer has a single phono line out for a sub, but the MS309 has L/R stereo line in's. How should I connect these?
    I know it may seem simple, but I don't want to do any damage!
    Thanks in advance,
    Mike.
  2. shodan
    shodan
    Dec 11, 2001
    11,705
    shoeburyness
    +6,807
    Just use a single phono to phono cable from the output to one of the input's.
    Or, you can get a phono splitter (Maplins or some such place) and then have the single out to both inputs. I believe this gives the sub a single about 3db higher than the single cable option and it also helps if your sub is set to Auto instead of continuesly On.
    Hope this helps!
  3. jeff-o
    jeff-o
    shodan is right. On my Paradigm subwoofer, splitting the signal to both inputs actually boosts the signal by 6 dB! Either way is correct, though.
  4. Nimby
    Nimby
    Jan 27, 2004
    9,204
    The Danish Bacon Factory
    +671
    I have read that "splitting" may increase the output but it doesn't increase the headroom. So I suppose in theory you are reducing the dynamic range of your sub. Though I can't confirm this. Since it has only just occurred to me. :)
    Nimby
  5. Dfour
    Dfour
    Jan 19, 2004
    4,091
    71
    Bracknell
    +86
    MS recommend the single sub cable be put in the LEFT IN on the sub.
    :rtfm:
  6. mjhbell
    mjhbell
    May 26, 2004
    19
    Thanks all,
    I'll stick with a single in to left and see how she sounds.
    Cheers,
    Mike.
  7. Dfour
    Dfour
    Jan 19, 2004
    4,091
    71
    Bracknell
    +86
    Mjhbell
    If you have your sub in auto and find it sometimes sluggish to wake up fitting 2 cables will usually cure this. The esy and cheap way is to just leave the sub on all the time, as its a class D amp it doesnt draw much power aor generate much heat. ;)
