Sub connection question
Beddie
Hi, before I order a CHT10 from uncle eric, I just wanted to know about connectivity.
A low level cable will deal with home cinema, but what about 2 channel music?
If I use the high level inputs then won't I get double the bass when watching a DVD?
Is it a case of unplugging/swapping connections when swapping sources?
If anyone has a clue what I am banging on about and can help I would be very grateful.
Ian J
The low level connector should deal with two channel music as well. Just tell the amp that you have small fronts and all bass will be redirected to the sub.
R
ricdiggle
Depends on the Amp too and which DACs you want to use for decoding the CD.
BUT...
Basically and to cut this short, I would use a low level signal for both.
Richard
