Sub connection query
Discussion in 'Subwoofers' started by gregmcquaid, May 18, 2005.
  1. gregmcquaid
    gregmcquaid
    Aug 20, 2004
    279
    Bristol
    +10
    I was wanting to connect a subwoofer to my amplifier (Yamaha AX-396) but it does not have a deicated subwoofer pre out, i also biwire my speakers to the amplifier so i am confused on how i would connect a subwoofer to the amp via speaker wire?
    One other thing i should note is that on the back of the amplifier i have a L R jack labeled OUT (REC), obviously this ouputs a signal and was wondering if i could connect it up to a subwoofer that way.
    Greg
  2. bob1
    bob1
    Nov 7, 2002
    4,316
    Sheffield
    +128
    Do you have this subwoofer yet?
    Most subwoofers will accept high level speaker connections so connecting your amp would not be a problem.
    Failing that as long as the subwoofer as a crossover you use the rec out.
    Saying all that my sub as neither :eek: :D .
  3. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,529
    Near London.
    +208
  4. gregmcquaid
    gregmcquaid
    Aug 20, 2004
    279
    Bristol
    +10
    Do you know how i would connect a sub to this amp with high level connections, my mains are bi-wired to the amp i cant see how this is possible.
  5. PJTX100
    PJTX100
    Dec 21, 2004
    8,129
    +562
    I think your options are
    - forego the bi-wiring
    - get a different amp
    - forget the sub
    ...unless someone can advise that you can stuff the sub and main speakers into a single set of high level outs...PJ :)
  6. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,529
    Near London.
    +208
    With many subs you can indeed use both sets of wires from a single set of binding posts.
  7. gregmcquaid
    gregmcquaid
    Aug 20, 2004
    279
    Bristol
    +10
    Ok so now i have that cleared up i just have to start looking for a subwoofer now.
    Any sugestions? Around 250-300
    Greg
  8. PJTX100
    PJTX100
    Dec 21, 2004
    8,129
    +562
    BKXLS200 :thumbsup:
  9. Nimby
    Nimby
    Jan 27, 2004
    9,201
    The Danish Bacon Factory
    +669
    I'd suggest you remove one cable from each speaker. Switch off your amp first of course just in case you cause a short.
    Now link the biwiring terminals on your speakers with the supplied links or some speaker cable core. It is considered a good idea to strip back your speaker cables just far enough to pass through both sets of terminals (treble and bass) rather than use the supplied linking bars. Experiment to see if you notice any difference.
    Now use the free speaker cables for stereo connections to your subwoofer's high level input terminals. In stereo L & R and maintaining correct phase.
    It's what I did. It makes life so easy and biwiring doesn't improve anything anyway.
    An alternative, if you are determined to retain your biwiring, is to take a new length of speaker cable from the bass terminals on the back of each speaker to your subwoofer input terminals. Again maintaining stereo and phase.
    Watch out for stray strands shorting between + & - terminals while you are messing about behind your speakers.
    You don't even need to touch your amplifier speaker output terminals. Because they cables are already in place from the biwiring connections at the amp.
    Nimby
  10. bob1
    bob1
    Nov 7, 2002
    4,316
    Sheffield
    +128
    Yep your right din't think about that :oops:.I must of been thinking of the elatsic band fly wheel method. :D
