Spick72
Established Member
Hi all, I currently run a Denon 3600 with a B&W ASW 608 sub and am picking up a new musical fidelity amp tomorrow to use as both a power amp with its HT bypass for my L/R channels and as a 2 channel with a Node 2i as its source. My question is, if I connect the MF to the sub via high level for the best audio connection in 2 channel mode and it is also connected via single rca to the lfe on the Denon then when it is being used as a power amp for movies the sub will be connected to both amps at the same time? I get how it connects for 2 channel and I get how it connects for HT but how would it work together? Proper head scratcher. Can anyone help? The MF amp does have pre outs and the sub has both high and low level inputs if this helps
