Sub Cable
Discussion in 'Subwoofers' started by lemming, Apr 16, 2003.
  1. lemming
    lemming
    Mar 4, 2003
    350
    19
    Garden of England (apparently!)
    I was supplied with a cable for connecting between my AV receiver and Sub, this is a single cable with one plug on each end, do I connect the 'Sub end' into the line in, if so which socket L or R??
    :confused:
  2. Squirrel God
    Squirrel God
    Use a "Y" adapter.
  3. Ian J
    Ian J
    Aug 6, 2001
    25,528
    +4,906
    That depends on which type of sub you have but on most it doesn't make much difference.
  4. MarkE19
    MarkE19
    Aug 10, 2002
    17,131
    Rainham Essex
    +2,393
    If your sub has and you use 'auto on' feature then use a 'Y' adapter as this will help to prevent the sub switching off during quieter scenes/music. Else just read the manual to see if it recommends one or the other, if not then just choose one.
    Mark.
  5. lemming
    lemming
    Mar 4, 2003
    350
    19
    The Sub is a Mordaunt Short MS308. It Does have an auto/on switch. The manual does not mention Y connectors, or recommend how/which connection to use (L or R or both).
  6. MarkE19
    MarkE19
    Aug 10, 2002
    17,131
    Rainham Essex
    +2,393
    Then as I said above use a 'Y' connecter if useing Auto or if not just use either of the inputs, it does not matter which one.
    Mark.
  7. bob007
    bob007
    Better still don't use the Auto On/Off and leave the sub On all the time, no harm will come to it, connect the lead to "L" seems to be the general rule.
    Also if your cable was supplied with the sub it might be an idea to purchase a better quality one, one that has decent sheilding. ;)
  8. lemming
    lemming
    Mar 4, 2003
    350
    19
    Thanks for the your help/advice people......much appreciated.
  9. groundy
    groundy
    Dec 8, 2001
    1,553
    39
    Northern Ireland
    I connect my sub cable to Line In R.
