Sub Cable?
Discussion in 'Subwoofers' started by gingerone, Feb 26, 2003.
  1. gingerone
    gingerone
    Dec 10, 2002
    2,381
    +283
    Any difference between a digital co-axial cable and a sub cable?
  2. Apocalypse
    Apocalypse
    Aug 14, 2002
    840
    19
    Sheffield
    AFAIK a digital coax phono is rated to 75 Ohms strictly whereas a standard phono is not strictly 75 Ohms, that's what a salesman at Superfi said anyway.
  3. gingerone
    gingerone
    Dec 10, 2002
    2,381
    +283
    So would a digital co-axial cable be as good as a dedicated subwoofer cable, when used as a sub cable?
  4. gingerone
    gingerone
    Dec 10, 2002
    2,381
    +283
    Anyone know?
  5. damtom1
    damtom1
    I've used both dedicated sub lead and standard single phono to phono,i dont think there is any difference.There is probably a difference as the price of the leads gets higher.
  6. gingerone
    gingerone
    Dec 10, 2002
    2,381
    +283
    Thanks for that. I'll not worry too much about getting a dedicated sub lead then.
