sub cable
Discussion in 'Cables & Switches' started by rickyd, Sep 11, 2012.
  1. rickyd
    rickyd
    Jun 29, 2004
    1,213
    Nottingham
    +49
    I am having a move round of my gear, and want to move my sub.
    so i am going to need a longer sub cable! I have just found in my garage an 8m length of component cable...."Canare v3-4CFB 605 75ohm coaxial cable made in japan" written on the cable.
    Could i use one of the 3 lengths for a sub cable? Is component cable ok to use?
    rickyd.
  2. cjohnson6
    cjohnson6
    Aug 13, 2005
    816
    Salisbury
    +54
    Yep, it's perfect.
  3. Andy8421
    Andy8421
    Nov 30, 2007
    672
    43
    +101
    Yep, that should do OK. Frequency response isn't an issue, only possible problem would be induced hum if you run the cable close to mains leads - though the component cable should be pretty well screened. Give it a try.
    I use RG59 cable (75ohm coax) for my sub and it works fine.
  4. rickyd
    rickyd
    Jun 29, 2004
    1,213
    Nottingham
    +49
    Thanks guys ill give it a go....
    Ahh But..begs the question,.. what colour will give the best performance, Red Blue or Green? :D:laugh:
