Sub Cable
Discussion in 'Subwoofers' started by philthyanimal, Jan 28, 2004.
  1. philthyanimal
    philthyanimal
    whats the difference between a suwoofer cable and a normal rca to rca(usedfor composite video) cable.
    It's just i need a 10m sub cable and most are are around £50, but a normal 75ohm rca to rca(they look the same) are about £20
    Anyone knowof acheapplace to getsub cables. I need one for the weekend.
    So mailorder would be best.
  2. common
    common
    Mar 5, 2001
    1,384
    41
    Oxford UK
    +8
  3. lowrider
    lowrider
    Sep 29, 2003
    676
    Riga, Latvia
    Thats probably because you didnt try other cables... ;)
    We did some tests the other day, and QED qunex was much better, and Audioquest G-Snake even better, for almost half the price of the QED... :smoke:
  4. Noodle
    Noodle
    Jan 6, 2003
    577
    Peterborough
    Lowrider,
    Where can I get the Audioquest cable you mentioned from??
    Ta,
    Ben.
  5. Ian J
    Ian J
    Aug 6, 2001
    25,528
    +4,905
    I have already had a Google for the G-String Snake but don't think it is sold in UK
  6. common
    common
    Mar 5, 2001
    1,384
    41
    Oxford UK
    +8
    I've tried loads mate - but within the budget mentioned (£20 for 10m) I think profigold would be an ideal choice as they offer good value for money
  7. lowrider
    lowrider
    Sep 29, 2003
    676
    Riga, Latvia
    Audioquest distributor for United Kingdom
    Marantz UK Ltd
    Kingsbridge House
    Padbury Oaks
    575-583 Bath Road
    Longford
    Middlesex
    UB7 OEH
    Tel No +44 (0)1753 680868
    Fax No +44 (0)1753 680428
  8. lowrider
    lowrider
    Sep 29, 2003
    676
    Riga, Latvia
    I appretiate that you where concerned by his price worries, but as he asked if there are differences, I just said there are major ones, that, IMHO, justify the price... :rolleyes:
  9. FoxyMulder
    FoxyMulder
    So how come i often hear people saying theyve used a coathanger as a cable and then used expensive 500 pounds a metre cable and heard no difference to sound quality, are you all now stating cable does make a difference ?
  10. fufna
    fufna
    Make your own. it costs less money and you can make them to your exact personal spec.
  11. philthyanimal
    philthyanimal
    Thanks for the replies.
    I've ordered a pro fi gold (thanks to common for the link).
    In all honesty i cant justify spending a fortune on a sub cable.
    I've been using the composite video lead that came with my DVD player and it sounds ok.
    But now i've moved my room round to cope with 7.1 i needed a 10m cable.
  12. lowrider
    lowrider
    Sep 29, 2003
    676
    Riga, Latvia
    You will be OK as you didn´t try better... ;)
    But the G-snake is not that expensive either, US$50 for 7 meters... :rolleyes:
  13. bobbypunk
    bobbypunk
    There is no answer to why some people hear a difference, it may be psychological, but why isn't important if it sounds better it sounds better. After spending alot of time trying different cables all of the time, I think I hear a difference. With Sub cables it wasn't always the most expensive that sounded best (suprisingly the best value for money I found was Cabletalk Video3, which I only used once to keep cables tidier as the one I used was only 1m long)
