Sub "bumping"??
Discussion in 'Subwoofers' started by Malone, Sep 29, 2003.
  1. Malone
    Malone
    Mar 12, 2001
    1,857
    Ilkeston,Derby
    +71
    Not much info to go on im afraid.
    A work colleague has a Yamaha receiver and a Pioneer DVD. He has a 6.1 setup and the sub is connected via a phono type lead between Sub out on the receiver and line in on the sub. Unfortunately he couldnt remember the Yammy model number but believes its from the RX range ? Anyway everytime he switches sound modes I believe the sub "bumps" in his words
    Any ideas anyone??
    Matt.......
  2. James45
    James45
    Sep 21, 2002
    2,844
    59
    Taking Care of Business
    it's supposed to, every sub gives a slight 'kick' when its turned on.
    If it's switched on but the plug is off and then flicked on (not the proper way to do it) you'll hear a much louder bump.
  3. Andywilliams
    Andywilliams
    Sep 27, 2002
    2,078
    notts.
    +63
    Hi Malone
    Dennis off this forum had the very same trouble with his sub.What had happened was that he'd been pulling the subs phono lead out when powered up this in turn damaged a capacitor in the amp which blocks noise when switching modes.Dont think it was expensive to get repaired.
    Hope this helps Gonzo.
  4. wookie
    wookie
    Blown Muting transistors.:lesson:
  5. dennis
    dennis
    Jul 2, 2003
    1,239
    surrey
    +54
    yes gonzo's got a good memory!it was something called a muting transistor that had gone in my ax10,it didnt cost me anything,still on guarantee,but it has been ok since being done,
    moral of story=TURN SUB OFF!BEFORE PULLING CABLES OUT!:blush:
  6. Malone
    Malone
    Mar 12, 2001
    1,857
    Ilkeston,Derby
    +71
    Top Job, Men
    Matt.........::smashin: :smashin:
