Sub-bass hook up cable
Tafflad
I need to decide on the cable to connect from my Yamaha amp (Sub bass out) to the BASH amp input on an SVS sub.
I am assuming that I use a coax, as there are no high frequencies going over this does it make much difference what to use ?
I have done some searching of the forum ... only really good reference was to the Mark Grant LV77S ... but that seems expensive for a signal cable that is mono, and carrying no mid or high frequencies and high current requirement.
