Sub & Amp Query (general knowledge)
Discussion in 'ICE, Sat Navs & Dash Cams Forum' started by pug106, Aug 7, 2005.
  1. pug106
    pug106
    i want to buy, a sub, and an amp for my 106.
    i have a £400 budget.
    Now i was wondering about Wattages & Ohms.
    If i buy, say for example. 2x 12" Kicker L7 solobarics, with a wattage each of 750Watt rms, 4ohms. Then would a 1500watt rms amp MONO D block be ok to run the both?
    Also would 2x 4ohm subs = a 2ohm setup?
    Also, as the mono D amp would only have one speaker output for one sub, how would i wire it for both the subs, or would i need a 2 channel amp? becuase i thought mono d's were better for subs, as there pure bass amps.
    thanks in advance. scott.
  2. lynx
    lynx
    Jan 20, 2002
    4,633
    It always rains.
    +301
    http://www.kicker.com/05/05kicker.html go to support - sub to amp guide if you are unsure.
    2x4Ω subs would not necessarily give 2Ω,it depends on a few factors. Single or dual voice coils and whether connected in series or parallel.
  3. T-Bone
    T-Bone
    Jan 16, 2005
    1,517
    48
    +52
    whats the rest of your setup like?
