Sub Advice
Discussion in 'Subwoofers' started by Duffy502, Mar 29, 2005.
  1. Duffy502
    Duffy502
    I have a room that measures 6 x 4.5 metres with a vaulted ceiling.
    Currentlly I an replacing my sub, those on the shortlist are;
    Velodyne CHT 12R- Huge, but fierce should work ok with my Harman amp?
    MJ Reference 200, tiny-up to the task??
    or the REL Stampede-see above??
  2. benbo
    benbo
    Mar 25, 2005
    26
  3. Duffy502
    Duffy502
    Thanks for the reply, i thought i was all alone out there!!
  4. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,545
    Near London.
    +208
    Based on specification alone I would think the Velodyne CHT-12R would be the better option. Your room is certainly a large one! May also be worth considering the Quad L series Sub which by all accounts is very good and comes in at around the same price bracket. :)
  5. Ian J
    Ian J
    Aug 6, 2001
    25,628
    +4,905
    Much depends on what you want the sub to do as if you intend to play action films at high volume you will need to look at something different than if your prime requirement was for a little extra bass on music.
  6. Duffy502
    Duffy502
    I have a comprimise system, which I guess is becomeing more common place;
    Harman 630
    Pioneer DVD
    Arcam CD
    so movies and tunes, it's all good.
    Dont want rumble for the sake of it, or a sub out of its depth, so to speak.
