Sub advice needed
Discussion in 'Subwoofers' started by PFM, Jun 15, 2002.
  1. PFM
    PFM
    Sep 24, 2000
    453
    Barton Upon Humber
    +17
    Need some help for a friend of mine. He's just got hold of a pioneer 5 speaker setup, the spec is set out below. The speaker system is a sattelite & sub package but he's got just the sats and is in need of the sub (or a sub to match them).
    Sat Speakers:
    Pioneer S-DV55ST-Q
    Max. power 40W
    Puissance 40W
    Impedance 8 ohms
    The subwoofer with the kit on the Pioneer web site stated a Frequency Response of 30HZ-350HZ
    Does anyone know if these subs are available as a seperate item?
    If not any suggestions for a suitable sonically matching sub would be gratefully received.
  2. Jase
    Jase
    Mar 16, 2001
    10,721
    United Kingdom
    +2,490
    Dont know about the Pioneer sub but most subwoofers will match quite well with all sorts of speakers. Its worth checking out the Paradigm range, the PDR 10 & PS1000 or if your friend wants to spend more consider a Rel or M&K sub.
  3. PFM
    PFM
    Sep 24, 2000
    453
    Barton Upon Humber
    +17
    Yeah thanks for that Jase.
    I figured the paradigm may be the route for him to go down, do you know how carefully He'll have to match the frequency crossover (ie. the point where the pioneers start to bottom out & the frequency the sub takes over).
    Any ideas would be gratefully received
