Sub £300 speaker packages
Discussion in 'Subwoofers' started by furbs, Aug 12, 2003.
  1. furbs
    furbs
    At the moment im looking at the eltax liberty 5.0 and the mission m72 speaker packages, i would prefer bookshelf speakers and will most likely be combining them with a sony db1080 / db2000 or if funds run low a db790.
    Is there any more under £300 worth looking at and will they work ok with that amp.
    thanls
  2. overfloe
    overfloe
    Apr 23, 2003
    230
    16
    Newcastle
    check Tannoy MX-M range, they are doing around £200 - 300 mark
