Sub £300 LCD 15" TV 1024x768 PC
Discussion in 'LCD & LED LCD TVs Forum' started by sparkes, Jan 10, 2005.
Tags:
  1. sparkes
    sparkes
    Jan 10, 2005
    3
    I'm looking for a Sub £300 LCD 15" TV with SCART & 1024x768 PC capability. What should I buy?. It's something for the bedroom so I'm not looking for home cinema quality.
    If I'm being to tight tell me what I should be spending and what I should be buying.
    Steve
  2. sparkes
    sparkes
    Jan 10, 2005
    3
    Somebody must know?
    Steve
  3. mickbarlow
    mickbarlow
    Dec 1, 2004
    532
    +7
    buy a 15" TFT MONITOR for bout £150 , or even a 17" TFT for about £225 and a digital TV PCI Card for about £50
  4. Xelon
    Xelon
    Nov 16, 2004
    391
    +53
    Try ebuyer.com they have a UMAX/YAMADA 17" LCD TV, look in home entertainment/LCD TV's last time I looked it was £289 inc.
  5. zenki200
    zenki200
    Richer Sounds are selling a Relysis 15" for £199 (No scart but you can use RGB) but dunno what the quality is like. You can pick up the LG 15" screens for under £300 but not sure as to the connectivity. I just bought a 17" DMTECH for £350 and I am happy with in although other forum users don't rate it so highly.
  6. bspks
    bspks
    Aug 18, 2004
    27
    Just bought one of these Relysis from Richer Sounds for £199.
    Plenty good enough picture quality for bedroom, plenty of brightness & contrast (500:1) and a respectable 15ms response time.
    No scart at all though but does have phonos for composite video, audio and component video plus s-video socket and a PC VGA connector, comes with NICAM stereo Picture In Picture with a PC input.
    Downside is that sound although unusually for very small speakers is good quality it is not very loud even at max. setting.
    Also takes what seems like hours (probably about 5-7 mins) to scan the entire VHF/UHF band to store channels which you then have to re-order yourself.
    Not too much of a problem for most people but I intend to take mine away in my caravan in the summer which means a slow retune every time I arrive in a different transmission area because you cannot retune individual channels.
    Can't say about reliability yet cos only had it since Wednesday.
  7. delilah
    delilah
    TV for my caravan, :hiya: Looking for a small but 14'' plus up to 19'' widescreen lcd that will run with hdtv so can also use at home with sky hdtv esp until i get a really big tv in jan Just read the slow tuning bit with interest as I am not v good at tuning --esp every time it moves...also the weight needs to be v low also I could live with a built in dvd player - but for very cheap 250 or less anyone any reccommendations?
    pricerunner only had one a 19'' wt 4.5 kilo with dvd player from argos
    surely theres others?:) deh
