stuttering xbox
Discussion in 'Xbox Forums' started by jason t, May 10, 2002.
  1. jason t
    jason t
    Mar 4, 2001
    1,709
    48
    kent
    +38
    hi
    i have just bought an xbox and i am suffering with an occasional
    stutter i think its something to do wiyh the frame rate conversion
    has anybody else got this problem ???
    what is the cure???
    is it just bad games??
    will the next generation of games be sorted???
    the ps2 dosent suffer with this !!why does the xbox???
    thanks for the help
    jason
  2. Porrm
    Porrm
    Hello, My Xbox games don't stutter apart from Halo but I read somewhere that you should go into the settings and swith PAL60 off for Halo! This makes things a lot smoother!
    Which games are you having trouble with?
    I would call the Microsoft Helpline it's free
    Porrm
  3. jason t
    jason t
    Mar 4, 2001
    1,709
    48
    kent
    +38
    fifa world cup its not all the time but when it happens it bugs me!!!
    yeah i have tried the pal 60 setting as well,its better with it off but its still there.
    jason
  4. Stewart C
    Stewart C
    I am moving through some of the really graphic heavy San Francisco streets in Project Gotham and the X Box definately stutters in some scenes.
    Bad game design I think.
  5. spikeyboyo
    spikeyboyo
    Not had any stuttering on my box - playing Halo and PGR. Halo does hold for a micro second every now and then as it loads the next section, but its always at a check point so no baddies around.
    Spike
  6. magikkk
    magikkk
    All versions of Fifa stutter including the xbox one - poor programming is the cause not your machine - I've also had fifa not load properly sometimes, and once freeze midplay - anyone had the same thing? Please everyone don't say it serves me right for buying the game!
  7. jason t
    jason t
    Mar 4, 2001
    1,709
    48
    kent
    +38
    no havent had any problems like that just the occasional stutter,have you checked your disc is it clean??
    jason
  8. Stewart C
    Stewart C
    It's the games guy's plain and simple.
  9. magikkk
    magikkk
    yes checked that, there is a couple of little surface scratches though....now if that was a pS1 or 2 game it wouldn't have any effect but maybe the xbox is very sensitive.......anybody?
  10. magikkk
    magikkk
    Stewart are you saying you think my occasional loading freezes are due to the game itself?
  11. Stewart C
    Stewart C
    Occasional freezes are due to game loading effects. SOme games use the Hard disk to store information. Halo for example when you get to a save section the game pauses slightly.
    I am talking about stuttering, this is not a hard disk swapping mechanism, it happens when the X Box is working at it's hardest.
    Regards
