Stuttering wireless - Can I stop it?
Discussion in 'Networking & NAS' started by Desmo, Jul 1, 2004.
  1. Desmo
    Desmo
    Jan 4, 2001
    14,167
    Braintree, Essex.
    +5,829
    I've got a Buffalo G setup and all works well with good consistent throughput. I've got myself a Nebula DigiTV card on my main machine that can act as a server and send the data stream across the network. When I use the client software upstairs in my bedroom I get a constant stutter every 6-7 seconds. If it was normal data transfer you wouldn't notice it but as it's sending a digital video stream the picture goes blocky, pauses and has sound dropouts.
    When it's sending data it varies between 2.2-2.5MB/s. My wireless can easily pull through 4MB/s so I know that the overall throughput isn't my problem. I tried varying a few setting last night but nothing seems to work. My next step it to maybe tried a wired network to make sure it isn't the server software causing the problem.
    Any ideas?
  2. buzlightyear
    buzlightyear
    Oct 8, 2002
    959
    46
    London
    +119
    The digital tv only ouputs at 2 meg so as you say 2.5 should be enough. I would defo go for a wired network, just to test. Have you tried upgrading drivers/firmware for the cards and router? There are lots of updates to the Nebula DigiTV software too.
  3. Desmo
    Desmo
    Jan 4, 2001
    14,167
    Braintree, Essex.
    +5,829
    Haven't tried any firmware updates yet. I only really sorted this out last night so didn't have time to go through all the options. I think I'll run a wire tonight just to make sure it's not the server software causing the problem.
    BTW, for those of you with the Nebula card, their site says the latest build (4) will be released on the 12th :)
  4. buzlightyear
    buzlightyear
    Oct 8, 2002
    959
    46
    London
    +119
    Only do the firmware update as last resort though and make sure you have a wired connection to the router if you do. Ive had 2 routers die on me after firmware updates (Luckily both work ones) for reasons unknown. Ive got a 108 meg wireless setup now and get variable speed results, so many different things inturrupt the signals.
  5. Desmo
    Desmo
    Jan 4, 2001
    14,167
    Braintree, Essex.
    +5,829
    The thing that seems odd to me is that the stutter is dead on the 6-7 seconds every time, like clockwork. Maybe this indicates that it is something to do with the way the packets are being sent? Or maybe some form of handshaking comms from the NIC to the AP saying "I'm still here"?
  6. The Dude
    The Dude
    May 21, 2004
    6,283
    Beverley, East Yorkshire
    +2,601
    Desmo... Turn off 'SSID broadcast' on your WAP.. :smashin:
    I'd be almost certain this is causing the problem, SSID is broadcast every 5 seconds, and really screws with XP wireless connections in particular.
    You hit the nail on the head... It's the AP saying 'I'm here, this is my name' every 5 seconds...
  7. David PluggedIn
    David PluggedIn
    Oct 14, 2003
    544
    +10
    It sounds like there could be some Windows service sitting in the background that is taking resources, things such as anti virus scanners etc, so you should also have a look at those. There are a few sites on the web that give advice on what you can safely switch off for maximum performance..
    good luck!
  8. Desmo
    Desmo
    Jan 4, 2001
    14,167
    Braintree, Essex.
    +5,829
    Just VNC'd home to check the settings, and as I thought, it is already off :(
    I'll have a check of the services next to see if anything else is messing me about.
  9. The Dude
    The Dude
    May 21, 2004
    6,283
    +2,601
    that's my credibility gone then.... :rotfl:
    Erm... trying to think of any services which poll network regularly, but can't think of any which you can turn off without stuffing the network..
    I can't see it being just resources as a whole.., as you say it's too regular..
    Gotta be a network service of some kind IMO...
    Have you tried turning off QoS packet scheduling on the server PC ( assuming it's XP ) this is pants and not needed at all...
  10. Desmo
    Desmo
    Jan 4, 2001
    14,167
    Braintree, Essex.
    +5,829
    Yep, always have QoS turned off. Just for info I'm running XP Pro. Think the first port of call tonight is to try a wired network and see what happens, just to totally rule out the DigiTV software.
  11. morphman
    morphman
    I had the same with my wireless video sender, I would get a stutter every few seconds.
    I have a linksys router, so im not sure the options are the same, but the recommended actions were to:-
    1. Force a single operation mode for your wireless setup (ie. B ONLY, or G ONLY, NOT MIXED MODE)
    2. Enable Frame Burst in the advanced options.
    This solved my problems
