stutter once every second (audio and video stutter).
Discussion in 'Desktop & Laptop Computers Forum' started by gunawan w, Mar 12, 2005.
  1. gunawan w
    gunawan w
    Hi all,
    first, this is my system:
    Video card: GF4 TI 4200
    Driver version: 6.14
    Output resolution: 1024x768
    CPU: P4 3.0GHz
    Memory: 2x256 mb DDR
    OS: XP Home w/ SP2
    Player:Zoom Player 4.02
    Video Codec: DScaler 5 ouput YV12
    Video Renderer: overlay
    Audio codec: AC3 filter v:1.01a
    Audio renderer: directsound: Realtek AC97 audio
    ffdshow version: 20040709 SSE_2
    ffdshow filters used (in order)
    RAW VIDEO=YV12
    1. Resize: 1024x768, lanzcos 2, luma sharpen 1.2
    2. (output colorspace) YV12
    with this minimal setup, after playing for around 30 seconds, I get stutter once every second (audio and video stutter).
    Tried several version of ffdshow and reclock, no luck.
    If I remove ffdshow from ZP it play smooth, no stutter!
    I like resize and luma sharpen in ffdshow for enhancing video output, but I can't accept stuttering. I want to use Denoise 3D but it generates more stutter.
    Any help to solve this problem, greatly appreciated.
    Is there any other program similar as ffdshow (resize and sharpen) which can work inside ZP?
    thank's
    Gunawan.
  2. KraGorn
    KraGorn
    Aug 30, 2003
    4,745
    68
    Warrington
    +27
    There is nothing else like FFDSHOW. Try Reclock, while your description of the problem doesn't make it sound a likely solution it may help identify the cause, use 1.5beta10 and check the drop/repeat frame count and also the system clock adjustment. Make sure you set the correct refresh rate for the type of source material you're playing.
    Your PC is well up to the task, I have a 3.0 P4 and can resize to 1920x1080 using L2.
  3. gunawan w
    gunawan w
    thanks KraGorn,
    reclock didn't help. I use NTSC dvd and refresh rate set to 60Hz.
    Since your PC is similar with mine, may I know your bios setting?
    and do you use nvidia video card? if yes how do you setup your card?
