Stupid questions about component cables
Discussion in 'Cables & Switches' started by pilgrimchris, Nov 2, 2005.
  1. pilgrimchris
    pilgrimchris
    Sep 26, 2005
    209
    +9
    I'm sure this is a real stupid Q but... I've just bought a 32"LCD and a DVD player (Tosh 350) which I can connect by HDMI but have heard that its even better over component. Does a component cables (three cables) also carry audio or do i need to get another different cable to carry the audio??
    :lease:
  2. Rapid 17
    Rapid 17
    Jan 14, 2005
    904
    28
    +79
    Yes you will need a separate cable for audio. Geoff.
  3. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    HDMI is (generally) better than component, so I wonder where that (mis)information comes from!?
    Component cables do not carry audio, so if you were to use those you need additional cables. Note that component cables (as any other video cable) should have an impedance of 75 Ohm while analogue interconnects (for audio) should have an impedance of 50 Ohm.
  4. pilgrimchris
    pilgrimchris
    Sep 26, 2005
    209
    +9
    I know that generally HDMI is better than component but I've read in the reviews etc that for this particular DVD player (Toshiba 350) the performance by component is fantastic. (Having said that the performance by HDMI is great so I might not bother!)
  5. jessmith
    jessmith
    Mar 9, 2005
    141
    19
    I certainly wouldn't bother, because component will not carry HD signals , so when these start becoming more common, you will end up throwing out your component cable, or not recieve the full benefit of the new technology, which is closer to mainstream day by day. The BBC have recently recorded some made for TV shows in HD quality.
  6. Member 34135
    Member 34135
    HDMI is the route to go but component does support all hi def resolutions including 1080p.
    Andy.
  7. dynamic turtle
    dynamic turtle
    Mar 23, 2004
    1,524
    41
    Central London
    +17
    Not the sort of thing I want to hear after having just splashed out £50 on one of your component cables! (Tech-link WireXS - v. nice for the money actually).
    HDMI can only grow in popularity and usage in line with Hi-Def displays. And seeing as they will remain out of the reach of most consumer for some time yet, component (hopefully) has a lot of life left in it.
    Also, I'm guessing that when hi-def sets go down to the £400 mark, they will be using components of such low quality, that the end-result will be an abjectly low definition image!!
    DT
