Stupid Question?
Discussion in 'Projectors, Screens & Video Processors' started by moosie, May 15, 2005.
  1. moosie
    moosie
    Apr 25, 2005
    63
    Projector connections.
    About to buy a projector but can someone tell me ( and this might be a stupid question ). Most projectors don't have scart sockets. How does someone connect sky plus box / dvd ( sony davs300) and say an xbox to a projector at the same time. Or am I missing something?
  2. Dwayne Dibley
    Dwayne Dibley
    Dec 1, 2004
    843
    46
    Right Here, Right Now
    +222
    no not a stupid question..... if anything it's a question we should be asking the manufacturers.... for years we get told that RGB Scart is the way to go and as soon as I start getting with the program then they change the rules.....
    Actually I believe some of the Panasonic machines have scart input....
    I currently use component for the Xbox and S-video for DVD. I don't have sky + so can't advise on that. The connections I have are more than adequate but I plan to go the HCPC route soon (whatever one of those is!) and hope to connect via VGA.... that is supposedly the current way to go.... then there's HDMI. .... hope I've added some confusion to the mix!!! :eek:
  3. moosie
    moosie
    Apr 25, 2005
    63
    Still confused.
    You are using component for DVD and XBOX but not at the same time? Sky will need HDMI next year, most seem to be recommending DVD HDMI to HDMI. No doubt the next Playstaion and XBOX will be better through HDMI. Will projectors have 3/4 scokets similar to current TVs or is there a "box" I can feed all into before going to the projector?
    PS thanks Dwayne for the answer
  4. Timbo21
    Timbo21
    Dec 23, 2004
    4,471
    2
    2
    London
    +263
    I dare say there is some box, which will probably cost you much more than
    you're willing to pay, & convert RGB to component, which will do the job nicely :rolleyes: .
    I am about to buy a pj & will use my Sony RDR HX900 DVD recorder to convert
    the scart to cmponent.
  5. moosie
    moosie
    Apr 25, 2005
    63
    Would appear that there is a product called a "Hdmi switcher" which comes with a remote control. So when you watch Sky HD and want to switch to your DVD you push a button and it changes the projector input. The switcher is pricey enough but I'd imagine by the time we get Sky HD that some sweat shop somewhere will be churning them out for buttons. :clap:
  6. Daftboy
    Daftboy
    Jan 8, 2004
    505
    +12
    Keene Electronics for the Scart to 15-pin RGB or component.
    The Sky+ box (Version 1 anyway) has a S-video ouput.
  7. Malky1903
    Malky1903
    Jul 2, 2003
    1,908
    48
    Aberdeen
    +64
    Do you have an amp? An amp that's capable of video switching would makes things far easier to connect everything up to the PJ.
  8. Malky1903
    Malky1903
    Jul 2, 2003
    1,908
    48
    Aberdeen
    +64
    So does the Version 2 box ;)
  9. moosie
    moosie
    Apr 25, 2005
    63
    was that I would buy a projector, get sky high deft next year along with a hd dvd player and only be able to plug one in at a time.
  10. seb4213
    seb4213
    May 15, 2005
    25
    3
    I've got a benq PE1520 and have connected it up like this:
    PC - DVI (same sort of thing as HDMI)
    Sky+ - S video
    X box - component using the MS hi def cable
    PS2 - composite (not the best way, should use component really!)
    DVD - I have to unplug the s video lead from the sky box! and connect it!
    for the new X box 360 EVERY game will be in hi definition, so worth getting one with a DVi / hdmi input.
    I'm sure there is a switcher for hdmi about.
    theres one for composite on ebay for £15 but it looks quite cheap and I worry it might lower the quality of the picture.
  11. Malky1903
    Malky1903
    Jul 2, 2003
    1,908
    48
    Aberdeen
    +64
    Why? If it's because your DVD player doesn't have S Video out, why not get a Scart to S Video cable? Or am I missing something here. I can't see why you have to unplug the Sky+ box to plug in the DVD.
  12. seb4213
    seb4213
    May 15, 2005
    25
    3
    Because my projector only has one s video input and I only have one 10 metre s video lead, therefor it is in my sky+ for 95% of the time and when I want to watch a DVD i have to unplug it and put it in the DVD player. I could just buy an s video switcher box although I think I'm going to just get a DVD with DVI output instead.
    Heres a DVI switcher box BTW:
    http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&category=14968&item=5773458559&rd=1#picture
  13. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    12,789
    Somewhere in South Yorkshire
    +4,983
    In these circumstances, I suspect that many folk use their AV amplifier to do the switching, which is why, for those many, passing multiple video, SVideo or component signals down one cable to a projector isn't an issue.
  14. moosie
    moosie
    Apr 25, 2005
    63
    Denon have a new av receiver with 3 hdmi inputs and 1 dvi input. Only problem is that it will cost the same price as a family car. Think they'll come down in price rapidly. Everything seems to be going HDMI.
    PS
    I see the new Playstation 3 will have 2 hdmi outputs too 720p and 1080p and blu ray dvd. Was thinking about upgrading the DVD player too but I might hang on a bit longer to see what the future holds.
  15. helter
    helter
    Nov 22, 2002
    115
    the toshiba et1 has a scart socket and is 16:9 but doesnt have hdmi but it can be bought for around £400 which is ideal for a first pj
  16. PC_112
    PC_112
    Feb 11, 2005
    229
    +3
    I will be buing a Denon 1905 or 2105. Can I connect evertyhing to the Denon (DVd with component, Sat with scart, video with s-video etc) and then sent just one component cable to the projector?
    Can these receivers transform s-video to component for example?
