Stupid question - What is the best way to wire Gallos
Discussion in 'Home Cinema Speakers' started by nhk, Mar 3, 2003.
  1. nhk
    nhk
    Dec 30, 2002
    82
    I have a 6.1 Gallo system (NM and MPS-150 sub). What is the best way to wire these.
    Should the satellites be connected to the subwoofer or should they be wired directly to the amp (Denon 3803) - and how do I get 6 speakers via the sub is another guess.
    The NM manual says the system is designed for 100W when satellites are connected to the sub. When connected directly to an amp, they are designed for 40W above 90Hz.
  2. perrdl
    perrdl
    Jul 29, 2002
    357
    19
    Worcester
    I have all of my Gallo's connected directly to the amp.
    I don't think that there is much point connecting them via the sub, as I think this is mainly for stereo usage.
    Hope that this helps.
  3. nhk
    nhk
    Dec 30, 2002
    82
    Thanks - will connect directly to amp.
