Stupid question re: filter cleaning
Discussion in 'Projectors, Screens & Video Processors' started by Smurfin, Jan 19, 2003.
  1. Smurfin
    Smurfin
    Aug 13, 2002
    20,507
    +3,825
    Well I'm amazed that I've used my Z1 so much, I checked the lamp hours tonight and it's up to 125:eek:
    How can I tell if I need to clean the filter? After how many hours do people normally do it?
    Has anyone actually done this yet on the Z1?
    cheers
    Matt
  2. theritz
    theritz
    Aug 17, 2002
    2,451
    Ireland
    +27
    Hi Matt,
    Glad to see you're clocking up the hours - sure sign of a happy PJ owner.
    I don't know if there's a lot of palavar in taking the filter out of the Z1 - prob not. The filter pops out of the AE100 easy and you can see quite clearly on the foam surface of the filter, extremely fine white dust in a pattern matching the inlet grill. Its recommended to clean it every 100 hours - but I normally do mine every fortnight or so - a quick wizz with the hoover with the narrow nozzle does the trick.
    The filter in the Panny is very flimsy - care is needed so the piece of foam doesn't end up in the hoover bag :eek: . So if the filter in the Z1 is in the same category, take care.
    See ya,
    Sean G.
  3. snocrash
    snocrash
    Dec 27, 2002
    103
    bear in mind that most internal dust 'blobs' occuring inside the project (lens, mirror, prism, LCD panel) are caused when the user changes (cleans) the filter.
    Create a negative pressure zone around the filter while removing it and reinserting it. Typical way of achieving this is to put a vacuum cleaner nozzle near by (Make sure the actual Vacuum engine is as far away from where the project as you can make it)
