Stupid Question (probably)
WozzaTT
I still haven't got my head round the difference between a widget and a program.
For example if I want to add Music to my homepage I see that it's available as either of the above. What would be the difference?
TIA
RedAl
TIA
I`ve often wondered this. I "think" that programs are simply the small icon you add to one of the 7 home screens whereas some of the wdgets have the option of being bigger and showing more information. I`m sure there`s someone eout there that can explain it better than me tho ;-)
bigtunes
That's more or less it.
A programme is a shortcut to the programme, just like on your desktop on your pc.
A widget has a user interface.
To use the example in the op, the music programme opens the player, the widget allows you to play music and select tracks with out opening the 'full' player.
