Stupid question about the side of my Beamax screen
Discussion in 'Projectors, Screens & Video Processors' started by Frankeh, Oct 22, 2005.
  1. Frankeh
    Frankeh
    Ok I just received my first projector screen ever, and I probably have the most stupid question about it too ;)
    which side does the projector need to project on? It isn't written anywhere in the manual.. one side is "granulous" and the other one is smooth
    I think the granulous side is the one I need to choose? (I have a beamax A series framed screen)
  2. fortean
    fortean
    Nov 28, 2004
    825
    Chorley
    +71
    The least shiney side is probably correct. If it's framed then there should be a flush side which you would use.
  3. Frankeh
    Frankeh
    flush side? what do you mean with flush?
  4. fortean
    fortean
    Nov 28, 2004
    825
    Chorley
    +71
    I would assume a framed screen has the material stretched over one side of a frame. The side of the frame that the material is stretched over will be the flush side. From your response I am guessing there is a black trim fitted over the frame.
  5. fortean
    fortean
    Nov 28, 2004
    825
    Chorley
    +71
    Is it a Beamax A Velvet?
    You still need to project on to the matt side though.
  6. Frankeh
    Frankeh
    It isn't the Beamax A Velvet, the regular A serie
  7. fortean
    fortean
    Nov 28, 2004
    825
    Chorley
    +71
    Can you not just try both sides before you fix it?
    Otherwise you will have to wait for someone with a Beamax screen to answer you.
    By the way, it wasn't a stupid question. You'd think screen manufacturers would have the sense to indicate which way round to use them; when it isn't that obvious.
  8. Frankeh
    Frankeh
    how can I "try" both sides before fixing it?
    I've putted on the wall, with the granulous side.. Isn't it logical if the granulous wouldn't be the right side than why would they make it granulous? they could just make the wrong side flat, instead of making it granulous, no?
  9. inzaman
    inzaman
    Dec 16, 2002
    8,018
    Derby
    +1,082
    For my A series i used the mat side, the shiny side seemed too shiny for a screen imo.
  10. 0B1-1
    0B1-1
    Frankeh, Why don't you just phone beamax !!!
    Use your inititive mate.
  11. psflynn
    psflynn
    Nov 10, 2003
    346
    Swindon
    +5
    as inzaman says - its the matt side. I got one too.
