Stupid question about satellite wires
Discussion in 'Home Cinema Speakers' started by Abadd, Jan 31, 2003.
  1. Abadd
    Abadd
    Help a newbie out
    Im currently having an extension built and wondering if its possible to pre-install wiring under the floor for my rear satellite speakers, Ie connect them to a wall outlet. Im thinking of buying the Kef eggs to go with my Pioneer VSXD2011 so im wondering exactly what wire they use and if its possible to buy some, run it under the floor and just connect the satellites to it.
    I know nothing about this stuff and satellites could use the same as any other speakers for all I know or it could just not be possible. Either way, advice please? :rolleyes:
  2. alexs2
    alexs2
    Nov 13, 2002
    13,957
    +1,671
    Pretty much any reasonable quality wire(by which I mean for the quality of your speakers)would be fine,and some of the QED wires would be a decent starter.
    As for laying the wires under the floor...excellent idea...if you're going down this route,it may be worth placing the wires in some sort of plastic conduit(especially if it's a concrete floor you're having laid,as you can upgrade the wires or replace them if necessary and pull them back through the conduit to install the new ones without ripping up the floor.
  3. Abadd
    Abadd
  4. gimli
    gimli
    Cabletalk 3.1 is an excellent speaket cable and at £2.50 per metre a reasonablt price as well. I wouldn't buy anything more expensive than this for Kef eggs on rear duty.
  5. Abadd
    Abadd
  6. Ian J
    Ian J
    Aug 6, 2001
    25,628
    +4,905
    But by all means buy QED Silver Anniversary at twice the price if that makes you happy. :suicide:
  7. Abadd
    Abadd
    The thing is, its now going up the walls, to be fixed behind the plaster so I want to make sure I have a high quality wire that will work well with the Eggs but be of a decent quality if I upgrade to more expensive speakers in the future. So im going with a budget of about £5 pm and I assume QED SA is a good cable for the budget.
  8. Abadd
    Abadd
    Another possibly daft question (sorry)
    Im assuming the eggs cant be bi-wired. Would it be a good idea to install a bi-wire in case I buy better speakers in the future that can or will the eggs not work normally with a bi-wire?
